The centre connector sometimes fails, mine had to be changed, luckily FOC by the main dealer.
Jiggling around occasionally got a momentary connection so I knew mine had power to the socket.
Get a test meter and check for continuity between the outer section and a good earth point.
Then check for voltage between the centre pin inside the socket and earth (with the ignition on).
