brandwooddixon
- Jul 31, 2006
- Location
- Wolverhampton
- S63 Coupe 2014
Are you certain that there's not a kink in the pipe?I got my hydraulic lines repaired basically and they made the rear left side about 3 cm longer and it did take me time to get it into angle to screw it into the valve block do you reckon that might be the issue I was thinking of disconnecting it and try and see what the pressure would be id assume there wouldn't be any but would it be worth the try? Or getting the pipe shorter by 3cm
