clk w208 cruise control inop
N
nismo915
my cruise control used to work really well but lately it's very intermitten and sometimes works will work for a minute before it slops working and the car slows down.
do you think this could be a faulty switch or ecu?
MB Service Centre
Mansfield
www.mbservicecentremansfield.co.uk
A210 E320
Not poss to say with out getting it on star, could be cruise switch, brake switch, or ecu switching it off,
If it dose the same fault all the time then at least you know it will do it if you get it booked in somewhere for diag
N
nismo915
i there anyway of testing this myself, try to elliminate things?
At what speed does this happen,at speeds in excess of 60mph a big tyre size difference can do this
Alex Crow
Super Suffolk
as malcolm, pressures can make a difference too.
failing that a session on star may help as mbsc says.
N
nismo915
saying that it works upto 50mph ok, could this be tyre related then??
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Have you changed the tyres recently? wrong profile, low tyre pressures have all been known to cause the problem you have described.
JEZ.S320L
Costa Calida, Spain
www.latorreonline.es
When I first got my ML, I had similar problems with CC. It was discovered (via advice from this Forum) that 2 of the 4 tyres were 275 and not 295. I ended up changing all 4 tyres. Result? No more problems with CC. :p
This fault then is either the differences in the tyres is too great or the speed sensors need cleaning but the former is the more likely
