CLS - Disc + Pad change.
KennyN
Paisley
As above people , the "Brake Wear" message popped up on the display a day or so ago . Cant complain as they are originals and nearly seven years old.
Checked the front disc wear and they are at 26.55mm , the wear limit is 26mm so i will replace them at the same time as the pads to save me doing the job in a year or so.
I am contemplating a set of "fancy" drilled / slotted discs for the front for no other reason than they look better than the stock ones.
So , after some Googling i have found these EBC ones for a sensible price so was contemplating using them with a set of the EBC Red Stuff pads.
Anyone had experience with these EBC discs , the mentioned pads seem to get a positive recommendation on this forum anyway.
http://www.ebay.co.uk/itm/GD1222-EB...el:CLS&hash=item4402ef4e21:g:W4MAAOSwhQhY4Q5a
Cheers - Kenny
bembo449
gainsborough , lincolnshire
I think slotted discs are overated and hum while in use , id go for drilled only pal , personal choice of course
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
I put drilled brembo discs and brembo pads on mine, for the look. 295mm. They stop no better or worse than standard MB 295mm.
KennyN
KennyN
Paisley
I am having trouble sourcing anything , drilled or slotted, apart from EBC in the required sizes , there are Black Diamond ??, Febi ?? and MTEC ??.
Brembo dont do them for the CLS in the sizes required (312mm x 28mm)
Kenny
I've had slotted Black Diamonds on my Smart for the past two years and they've been fine aside from pad deposition into the slots.
Slightly noisy under hard barking but otherwise you'd never know.
I'd avoid drilled unless the holes are cast in and finished with a drill as simply drilling discs creates stress points and they end up cracking outwards from the hole.
I'd never let EBC discs anywhere near my car as my previous experiences showed them to consistently give me issues with judder.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Kenny
Put standard disks and Red Stuff pads on
^ I'm with Jon- had that combo on my SL and it worked very well, virtually no brake dust either.
Something my 63 standard pads creates in clouds....pity they dont do Red stuff for mine- only yellow stuff and in the past I've been less impressed by those...
KennyN
KennyN
Paisley
That seems to be the way to go , OEM rotors and the EBC (red) pads. I will call the chaps at MB Grangemouth later today for a price as i can get one of the chaps in work to pick them up on the way home if they are competitive with my local dealer .
I cant be arsed with the potential messing around with some of the non OEM parts.
Thanks all - K
bembo449
aren't the red pads the most abrasive , as in for going like hell and will still stop no matter how hard you hammer them ?
Not sure on abrasive, they certainly stop you well- no discernible disc damage /wear but also little dust
KennyN
KennyN
Paisley
Called MB Grangemouth for a price for the lot and it comes in at £160 ish for the discs / pads / sensor so it looks like OEM all the way , better the devil you know than the devil you dont.
With an average daily journey speed of 17 mph then a set of Fred Flintstone stoppers would do me.
Kenny
And to be honest Kenny, nothing at all wrong with OE in this case!
Just a bit more dusty. Good price again
KennyN
KennyN
Paisley
The originals have lasted 6 1/2 years and 40k miles so this next set will see me through the ownership of the car.
I had a bit of a time fitting the aftermarket alloys which turned out to be a complete pain so at least with the OEM parts they should just be plug and play .
Kenny
AMGeed
Poole, Dorset
S204 C180K
Check out Akebono ceramic brake pads for your E63 John. Heard lots of good things about them and minimal brake dust.
Thanks Roger will do, havent heard much about those...
Any idea if they're available in the UK? Just found US on google..
PB53CLS
Paisley
2010 CLS350 CDI Grand Edition
Hi Kenny, I done the MB Grangemouth deal two months ago,everything for £156 and delivered to Fiat Renfrew Rd. free.Brakes are first class as far as Im concerned. Ask for Fraser.
