coil springs ml320 how to replace
I can print this info off now and send it to you
Wonderbloke
Essex
Ml270/2003/2.7cdi
Malcolm, i found a thread about rear coil spring fitment to a 2003 ml270cdi w163 and you advise you have fitting instructions? Since mine has just broken on one side the garage is quoting me £880 for the 2 and will only do the whole assembly.. Cannot afford it. Could you send me the instructions if you still have please to just do the springs?
Kind regards
Wonderbloke
Alex Crow
Super Suffolk
Give me a ring wonderbloke and I will quote you happy :D
Miffy
Bromley, London
CLK 320 CAB Elegance C208
wow, £800 for a pair of springs? I bet Alex can quote you happy Happy
New to site. Got to replace both rear coil springs on my ML320 (1999). Have got the springs now. Is it possible to send me info on how to do this. Many thanks.
Dave
Hello and welcome,,I can Email the info to you
Caravanman
Newquay, Cornwall
ML320/1999/320
Rear Coil springs
Hi Malc.
Any chance of you please sending me a copy of how to replace the rear coil springs on my ML320 (1999). I have sourced the spings but now need to fit them.
Many thanks Malc.
Dave
deal2hunt
New Registration
VA
ml430/2001/V8
Malcolm:
New to this site, I got 2001 ML430, recently found rear shock spring broken, and saw you might have the instruction to replace it. I am thinking to replace the whole set(a complete strut). wondering if you have the instruction for it.
Thanks a lot in advance,
here is my email mji512005@yahoo.com
Marshall
I have sent them,, if incorrect please say :D
Petemac
Inverness
merc c250TD 99/2000 150000MILES ON CLOCK GREAT CAR
ml320
can you email me instructions how to remove back passengers side coil spring and strut as bottom of strut fixing bolt is broken it is 2000 model w reg. my email is pmack580@yahoo.com thanks peter
TCEGraham
Bournemouth, UK
ML270CDi 2001 & Vito109CD 2007
OK you should have it :D:D
Hi there.
new to the forum having just purchased 2001 ml270cdi with 75k on the clock. Working my way through ball joint replacements, tie-rod inner arm, ARB bushes etc but stumbling on the rear springs which are broken. The shocks are off the car but i cannot find a tool to allow me to replace the springs. any advice here particularly welcome. I have the car stranded on a 2 post lift in a friends garage.(very embarrassing) MB are telling me they only change complete assemblies. Thanks, Graham
oigle
members.optusnet.com.au
Easiest solution is to take the legs and new springs to a workshop equipped with a good strong spring compressor. They should be able to change the springs over in 15 - 20 minutes if they are any good.
Beats buying a suitable compressor and risking your life with it "losing" the spring in the process - very dangerous.
Sorry I cannot help out on what to do it with :(
TCEGraham
Bournemouth, UK
Thanks anyway. There is a tool out there, it's just finding the right one. All the Best
Graham
TCEGraham
Bournemouth, UK
Thanks for your reply. I think I may have come up with an option so we'll see tomorrow. All the Best, Graham
Ardveen1
Wicklow
Ml270 CDI 2006,. SL320 1996,
Hi, I have a broken rear ( passenger side ) spring on a 2003 model Mercedes ML 270 CDI with spacesaver wheel underneath, could you please send on the fitting instructions, did I read somewhere that a 13 mm ratchet spanner is needed to remove the inner top bolt, my email is ardveen@gmail.com, thanks
www.W140.co.uk&www.r129.co
