Cold Start Valve - 250C, W108 1971
Chibs
250C , 1971, W108
Hello All
I've been told I need a replacement Cold Start Valve (or the entire housing module) for a 250C, 1971, W108 model.
Can someone help with how/where I can get hold of one pls ?
Do I have the correct description for starters :)
Ive attached some photos of the part if it will be of help
thanks in advance... Cold Start Valve .jpg CSV Module 1.jpg CSV Module 3.jpg
robparker
Taunton
The big metal thing is a thermostat housing, nothing to do with cold starting, or indeed any starting, and the top one looks like a temperature sensor that alters vacuum.. from the pic.. which may or may not be connected with starting
C
Chibs
250C , 1971, W108
Thanks Rob
You sound correct because the main pipe from the radiator to the engine goes through this module and it looks like the source for engine cooling.
These pics (with the yellow arrow) shows the precise location of the part
Any idea of how/where i can get one please ?
My poor ''Ruby'' has been stagnating in the garage for almost 5 months :(
C
Chibs
250C , 1971, W108
Photo 1.png Thanks Rob
Sounds accurate - as the main hose from the radiator passes through the big metal ''thing''.
Better photos attached
Any ideas on where/how I can get one please - my poor car has been stuck in the garage for over 5 months now :(
Thanks in advance
C
Chibs
250C , 1971, W108
Hi Rob
You were absolutely spot on - I checked on ebay and saw similar parts.
The correct description and part number is : OE Mercedes #1302030173 Thermostat Housing Assembly W108
Thanks a million
Any help with locating one would be much appreciated
thanks
robparker
Taunton
I'm not sure if I have one, but I'll check my stock tomorrow.
Rob
robparker
Taunton
What's actually the matter with yours, is it cracked?
