Condensation in 2022 315CDi headlights
Rowls1948
315CDi 2022 150bhp
Hi
I have condensation in both Headlights on my 2022 315CDi, as attached photos. It appears worse after a cold morning. Should this be covered under the warranty - Istill have a month left !!
sl500amgsport
Essex
SL500 2014
I doubt whether a claim under warranty would be accepted as they would report a small amount is normal and the condensation should evaporate...
See;-
Sent from my SM-G988B using Tapatalk
DSK
CLS 320 CDI, S350 Bluetec
I agree with the above but, as you still have some time left, it’s worth it. I would argue, did it happen when new? If not, then you have an argument. Does the other side have the same issue?
I do also wonder with all shoddy modern build quality and poor materials, if you have a very fine crack that may not be visible causing this?
sl500amgsport
Essex
SL500 2014
I had this on my SL which was a £100k car new, it soon evaporated when driven and would only appear occasionally parked outside overnight in winter, owned the car for 6 years and the lights never failed, I wouldn't worry..
DSK
Generally seen this sort of thing with a few modern cars, some get a bit around the main central lens, some by the odd led segment.
If it didn’t happen when it was new, for the sake of it, I’d log it now with the dealer and argue that needs revealing etc. If it’s happened from new, then sadly as above, one will have to live with it even though it’s a defect.
