Disabling EGR
Kev555
N.I
Dangerous talk, you will bring the forum police calling:D:D:D
Gazwould
C250 CDI
The NOx levels will be higher , but as we know NOx levels are much more real world higher than the manufacturers claim , so how much more real world with EGR delete when the engine breathes just cool clean filtered air ?
oigle
members.optusnet.com.au
Biggest difference I noted after deleting the egr was an almost total lack of particulates in exhaust. A much cleaner burn with excess oxygen. Better economy too which must translate to less CO2. If you are not using the vehicle in city areas, I see little problem with NOx, other than its legality.
IcemanGP
Limassol,Cyprus
w203/2005/c220cdi
Hi guys, I have a w203 c220 cdi 646.963 I have my EGR plug unplugged with a Dieselman circuit installed.
My internal heater has stopped working and I notice the heater take off is after the EGR valve on the EGR manifold, is this causing my problem or is it unrerleated?
oigle
Shouldn't stop the heater working but will reduce the amount of heat transfer and the speed of coolant warmup. You must have another issue.
Ian.
oigle
Should be enough reason
How about you quote my statement properly - If you are not using the vehicle in city areas, I see little problem with NOx, other than its legality.
If using in city, different story. In the bush, the effect would be unmeasureable.
Ian.
ajlsl600
france
Frankly until makers stop using it as reason to rob us, it will continue.
Simple solution,market all this crxx. At such prices fiddlin the system ain't worth the bother, simples. Authorities could help as well instead of watching the robbery legislate for emmisions kit to have 10 yr or 100,000 warranty. That will sort quality, reliability of the bits concerned. Cos, putin it simply, that "encourages" makers to make decent sensors ect. Result. Motorists happy, greens n snowflakes happy. Makers just find the next, screw us over thing.. Headlights, for example!
Farukkkk
W203 611
HELLO THERE. I have W203 c220 2002 model
I prepared the harness. I just want to be sure. I am aware that the problem is getting too long. My EGR converter is 2-wire. Is this normal? If it's true, finding the cables won't be difficult.
Sorry for the bad English.
MERHABA. W203 c220 2002 modelim var
Koşum takımını hazırladım. Ben sadece emin olmak istiyorum. Sorunun çok uzadığının farkındayım. EGR dönüştürücüm 2 kablolu. Bu normal mi? Doğruysa, kabloları bulmak zor olmayacak.
Kötü İngilizce için özür dilerim.
Hello and welcome,
Worth using google translate before you post so we can understand your problem
Farukkkk
W203 611
Hello again.
I found the wire that goes to the maf 5 cable yellow white plug 1. I did pin to pin in the right place. I detected the EGR converter wires yellow White 12v. I also connected an egr signal to the yellow black .
I ran it in parked still has black smoke. I'll do the road test later.
Please alert me if there is a place where I made a mistake.
Thank you very much to everyone who wrote here.
HERBIEMERCMAN
PRESTON, LANCS.
97. E300.TD. 7 SEAT.ELEGANCE. EST.TOYOTA SUPRA MK4. RS. VAUX. CORSA.GLS AUTO. SPORT.
SORRY FARU, I CANNOT FOLLOW WHAT YOU MEAN.
Kaurinho
Cl203/2004/c220cdi
Hallo people. I have problems with my GLA and om651 p0401 and p049b so EGR Valve. Is there any way to delete it on this engine? Any help?
Kev555
N.I
You can delete it through a remap or separately
www.ckinsurance.co.uk
