E-class coupe no crank issue
eclass coupe electric problem
  • no crank
    Votes: 0 0.0%
  • electric fault
    Votes: 0 0.0%
  • Total voters
mercedesc207
c207 2011 2.1
Hello I have a 2011 Mercedes E Class coupe
The car won't crack over to start
the dash lights turn on all fuses are okay
interior heating doesn't turn on
sometimes buttons on steering wheel don't work also the radio controls and seats
gearbox used to show up on the dash screen if its in park still wouldn't crank over
shows srs airbags on dash
don't know where to start to try and fix this problem or what is causing it not to start and help would be appreciated
Start with a battery check
Then the next stage is a diagnostic - Star via a Mercedes Independant best
Oh, welcome by the way- where are you based?
Sounds like a bad EIS but as above get codes read.
mercedesc207
c207 2011 2.1
just fitted brand new Mercedes battery
just done diagnostics no communication with front right sam unit
no can communication
EIS working key releases steering lock
That's only one function of the EIS. If the switch is faulty it may be not maintaining connection of switched circuits however if you have no communication with the SAM that's the place to start.
