digcot65
- Jan 15, 2017
- Location
- worcestershire
- mewrcedes w2203 2000
The right- hand windows work OK .however the lefthand front and rear don`t work.I`ve traced the wiring through to the connector in the door (black and green) they are fine and putting a wire from the +ve of the battery onto the green or black wire on the connector which is what happens pushing the switch,nothing happens,.How do I remove the motor to check it out,it doesn`t look an easy job.Len
