Electric windows C107 1980
digcot65
worcestershire
mewrcedes w2203 2000
The right- hand windows work OK .however the lefthand front and rear don`t work.I`ve traced the wiring through to the connector in the door (black and green) they are fine and putting a wire from the +ve of the battery onto the green or black wire on the connector which is what happens pushing the switch,nothing happens,.How do I remove the motor to check it out,it doesn`t look an easy job.Len
D
digcot65
worcestershire
I found the front window fails to move due to a faulty switch, however, the rear window motor isn`t working. If I put the battery across the two wires from the switch that feed the motor, nothing. How is the rear interior panel removed, I take it the seats have to come out, I just hope the rear motor isn`t as difficult to remove as the front one Len
D
digcot65
worcestershire
More checking on the windows and I have found the switch seems OK but the rear window winder motor is seized.How do I remove it from my SLC.the front window is now fine after I disconnected the rear motor. Len Cottam
