Engine don't stop e220 cdi 2003
Dinu
E220 w211
Engine don't stop with key off any one have this problem and fix it please let me know....
Do you mean the engine runs when you take the key out? Presumably we aren’t talking diesel runaway here otherwise your problem would already be solved (or just begun depending which way you look at it)
D
Dinu
E220 w211
Yes engine runs after I take the key out from ignition
Sent from my SNE-LX1 using Tapatalk
Naraic
2005 CL500.
Is it still running?!!
D
Dinu
E220 w211
Lol I stop it put my hand in air intake
Hope I found the problem new alternator was fitted and I checked now and I get only 12.33 and I order new one hope I sort it
Wet towel would have been safer! Anyway it’s done now.
Not imagining the alternator would cause this but I could be wrong. Others have experienced loose or broken covers on drivers side SAM which filled with water (Cole @ MBS I believe?)
I'm with with John on this one , it's not the alternator , I would stop spending money on new unrelated parts until the running on is sorted
robparker
Taunton
I had this once on mine and I just pulled the plug on the end of the fuel rail off to stop it, then it never did it again.. wierd!
Botus
S500/2010/500
never attempt to stop a tractor engine with your hand over the air intake.... u may find the engine runs happily on, but there is no skin or flesh left on your hand
D
Dinu
E220 w211
Guys car is running now
Only problem have now is enter in limp mode.....
