Do you mean the engine runs when you take the key out? Presumably we aren’t talking diesel runaway here otherwise your problem would already be solved (or just begun depending which way you look at it)
Lol I stop it put my hand in air intake
Hope I found the problem new alternator was fitted and I checked now and I get only 12.33 and I order new one hope I sort it
Wet towel would have been safer! Anyway it’s done now.
Not imagining the alternator would cause this but I could be wrong. Others have experienced loose or broken covers on drivers side SAM which filled with water (Cole @ MBS I believe?)
never attempt to stop a tractor engine with your hand over the air intake.... u may find the engine runs happily on, but there is no skin or flesh left on your hand
