Esp/bas
Boatlon
A140 2004
I have searched a lot of forums to try and ascertain my fault I have on an A140 , 2004.
Now I m not sure if the light has been intermittent before I removed the strut for a top mount replace but the steering geometry was upset but put back to where it was before and now turning the steering to full lock clockwise which is fine and then left , it triggers the light to reappear. The tracking upset by the removal of the strut and subsequently triggering the esp to come on.
I haven't checked the tracking as yet. So maybe the that upsets
The ESP light
B
Boatlon
A140 2004
  • #2
Does anyone know of the above query I have , would it be better if I got a fault code?
Yes, sounds like you have a dodgy steering angle sensor.
Easy sort ? Steering wheel off?
Not too bad usual. Airbag off, big nut in middle off, steering wheel off, then module comes out.
I would get the the codes read before changing parts at least.
B
Boatlon
A140 2004
Code is C1140. N39 (steering angle sensor) signal open circuit
B
Boatlon
A140 2004
Does anyone know if the sensor is expensive please
B
Boatlon
A140 2004
Haha , was looking myself and found one for £30 ! Guess it’s the cheap version
joderest
ML270 2003
Have you tried the SAS reset, might clear fault
B
Boatlon
A140 2004
Can you explain that reset, is that different from steering reset explained earlier please.
umblecumbuz
Wales and Gozo
And before throwing bits at it, have you had the tracking reset?
You will probably end up doing this anyway, as you suspect it might be out after your work, so why not do it first?
joderest
ML270 2003
Turn steering left to right three times, then drive away striaght
B
Boatlon
A140 2004
Ah yes that’s to do, and yes been through that procedure
B
Boatlon
A140 2004
  • #17
Tried the lock to lock three times and drive straight to no avail.
As the steering is straight at the moment I will check tracking , that can't be that far out to pick up the sensor calculation, however will check tomorrow , my diagnostic tells me at steering wheel sitting straight the angle sensor says 2.5 degrees so not far out.
B
Boatlon
A140 2004
  • #18
Now coming up with Ecus fault as well , why would you need such an aid any way!!!Arghh
B
Boatlon
A140 2004
  • #19
Oh and by the way had the mechanism off behind the steering wheel and could not see anything untoward, even checked the plug into ecu and it’s perfectly clean , I’m at a loss !!
joderest
ML270 2003
I think, but not sure i was told that it could only be 0.5 to 0.75 degrees out, other wise would throw up a code. The tracking has to be done with the steering wheel in the direct ahead.
