John Laidlaw
- Nov 15, 2013
- Location
- Wirral
- Land Rover Discovery 4
Aaargh Diamond cut!! Just be very careful not to kerb these Esa!
Buy some Collinite 845 and give each wheel at least 3 coats front and back before fitting them. This will prevent the diamond cut finish from white-worming itself into oblivion at the chance of rain, snow or slush.
Have you checked the offset on these and the wheel bolt size? MB have several different bolt sizes (12mm and 14.5mm from memory) and cup radii dependent on your model. I did this, bought AMG multispoke for my CL and had to source completely new (shorter) wheel bolts to fit the wheels on.
If you search on this site for "Wheel sizes" or "Will these wheels fit" you will find a sticky thread with links to various sites that will allow you to check.
On the bulbs, I must strongly advise you to not go down the blue white route. You may think they look cool but you will be sacrificing actual lighting performance (illumination of the road as perceived by the driver) for bling factor. Don't do it. I have or have had Osram Nightbreakers H7 or H4 variously fitted to 4 cars now and like many here can report that they are excellent. 2 of these cars have single xenon lamps too and the Nightbreakers are not readily distinguishable from the xenon colour temperature wise when full beam is on.
Mesh grille front? I hate to point this out but you have a beautifully styled MB, it isn't a Focus. Keep the bars and star, don't cheapen the look of the car- otherwise it will look just like a C class that someone has tried to bling up!
Just my opinion, but it's the right one
By the way, they're lovely wheels. Great find.
ok so i kind of just found out they have 'professionaly' been refurbished, guess he kind of lied but they are genuine and still look nice so i guess i will keep them....for now...
craig and john what would you do?
Having diamond cut wheels refurbished can be expensive, its very hard to get the clear top coat to stick well, it is also whats known as a weak finish as it contains no pigment. Some firms that do this work offer a 2 year guarantee but they charge £600 to do the job.
bulbs i have found these bright ones they are expensive and i think they do not sacrifice illumination like you said. so i found these (http://www.powerbulbs.com/product/crystal-vision-h7) for the high beam
and for the low beam these are expensive: Philips Xenon WhiteVision D1S (Single)
one is 4300k like craig mentioned
the low beam is 6000k
both look quality and abit expensive
Does the refurb look good?
the only issue if so then is that if the diamond cut has been done once, or worse twice or more, then you likely won't be able to do another refurb via diamond cut again as these actually get some material skimmed off each time.
In your shoes I would take them to a specialist in Diamond cut and ask them to check if they've been skimmed already, I guess they can tell. If they've been done and there's not much material left I'd reject them.
the wheelspecialist should be able to help. There is one in Manchester 0161
231 8337 Welcomb street M11 2NB
I'm sure there are loads of others, but I have used their sister branch in Ellesmere Port and found them to be good. My 212 I had previously had the same alloys as you now have and refurbed one of them (Skimmed) with good results.
they have been 'reconditioned' that what he said, so just confused whether i have made a good choice, in the picture they look good
he lied to saying oh we only have one pair and the buyer didnt want them etc so just annoyed
but if they are genuine and look spotless i guess wells ee
