gearbox fault clk 320 cdi
kingsandgreen
cornwall
clk270cdi 04/ clk320cdi 06/ slk230 convertable 01
hi all, I have an intermittent fault with my 7g box, occasionly when I try to go from drive to reverse the stick won't move pass neutral but if I take foot off brake will then change, once had to turn off engine to get shifter to move pass neutral box functioning normally other than this. no faults showing on code reader is there a micro switch associated with the foot brake clk 320 cdi 2006
Get it hooked up to check the codes , could be an ESM on its way out ...
K
kingsandgreen
cornwall
got a couple of fault codes, p1856, 240c seems to be pointing to ESM, £450 + vat for unit, do these units need to be programmed to car or are they plug n play been offered used one from reputable merc breaker but unsure about whether would need reprogramming
A fair question I can't answer! I suspect it will need coding but hopefully someone with Star will be along shortly to answer that, yay or nay...
Steve@Avantgarde
Bristol/Somerset
Snap On scanners are rubbish on MB.
Sounds like the gear selector module is failing. Quite a common issue. Suspected fault codes will be that there is no communication with the ESM and engine ECU.
K
kingsandgreen
cornwall
cheers steve, going to ring mer care in Plymouth for diagnostics, can a second hand one be fitted or are they programmed to car
Steve@Avantgarde
Bristol/Somerset
Yes, they are plug and play. We fit second hand units now and again to cars as a new GSM is around £650+VAT. Got one for my old mans E Class from Prestige All Parts the other week for £100.
K
kingsandgreen
cornwall
thanks for that steve, spoke to prestige £102 delivered will have star diagnostic tomorrow just to be sure, help much appreciated :)
Result hopefully, great when you have helpful folks like Steve on here!
