GUIDE: Basic coolant change (W208)
Status
Not open for further replies.
JSeaman
Derbyshire
C220 CDI 2005
Change your coolant when the car is cold, coolant is superheated when the car is hot as it is a pressurised system so never work on a hot car
Step 1 - See steps 1-5 of the oil change guide to remove the undertray
Step 2 - With the undertray removed, get some suitable vessels for catching fluids (the old coolant) ready
Step 3 - Lying with your head under the front of the car, on the passenger side you will find a small red bleed screw. You need to slacken this with a flatblade screwdriver
JSeaman
Derbyshire
C220 CDI 2005
  • #2
Step 4 - When you slacken the bleed screw, coolant will come out of the highlighted pipe, this takes a while though so it's quicker to remove a bigger hose (see step 7)
Step 5 - Catch all the coolant and dispose of at your local refuse dump
Step 6 - Remove the coolant filler cap
JSeaman
Derbyshire
C220 CDI 2005
Step 7 - Now pop to the other side of the rad and undo the bottom hose
Step 8 - Once completely drained, you can refit the bottom hose
JSeaman
Derbyshire
C220 CDI 2005
Step 9 - If you remove the drain plug totally there is an O ring you can replace then tighten this back up
Step 10 - Use a funnel to help you top up the antifreeze, use blue antifreeze
Step 11 - Refit the filler cap and run the car up to temperature checking for leaks (go for a drive to warm the car up quickly after you have done an initial visual inspection). Top up as required (but not when the coolant is hot!)
duncanh
Wiltshire
BMW 520d SE F10, formerly c220cdi estate (for 12.5 years and 345k miles), before that w124 and w210
Don't you also have to drain the coolant out of the cylinder block?
Silver_Star
Rural Leicestershire near where Pork Pies and Stil
W203.006, S211.208 Land Rover 90
Yes there is a drain plug on the block.
I also like to give it a flush in both directions with the hose pipe as well before adding the new coolant.
However the guide is entitled "Basic Coolant Change" so it is fine.
JSeaman
Derbyshire
C220 CDI 2005
You hit the nail on the head there, I put it as a basic change because there were 3 things I consider in a normal (or 'advanced') change:
1. Drain the block
2. Change stat
3. Back flush the system
James
wireman
lancashire
I would take off the filler cap as step one to let the coolant out faster.
Status
www.W140.co.uk&www.r129.co
