JSeaman
Change your coolant when the car is cold, coolant is superheated when the car is hot as it is a pressurised system so never work on a hot car
Step 1 - See steps 1-5 of the oil change guide to remove the undertray
Step 2 - With the undertray removed, get some suitable vessels for catching fluids (the old coolant) ready
Step 3 - Lying with your head under the front of the car, on the passenger side you will find a small red bleed screw. You need to slacken this with a flatblade screwdriver
