GUIDE: Changing your Air Filter (W208)
JSeaman
Derbyshire
C220 CDI 2005
Step 1 - Locate the air filter at the front of the engine bay
Step 2 - Undo the spring clip holding the air box to the inlet pipework
Step 3 - You will find several clips around the air box, simply pull the lower half up and fold the upper half out of the way to release the air box
JSeaman
Derbyshire
C220 CDI 2005
  • #2
Step 4 - Repeat for all the clips on the air box
JSeaman
Derbyshire
C220 CDI 2005
Step 5 - Unclip the hose from the air box, this is flexible and pops out easily
Step 6 - Release the bottom clip from the intake hose (as in step 2)
Step 7 - You can now wriggle the air box clear of the engine bay, be gentle, there shouldn't be much/any resistance
JSeaman
Derbyshire
C220 CDI 2005
Step 8 - You can now see your (filthy) air filter, simply pull this out
Step 9 - Give the pre-filter side a clean of any leaves/dirt, just wipe with a cloth or similar
JSeaman
Derbyshire
C220 CDI 2005
Step 10 - Grab yourself a nice new air filter (note the two heights of the filter fins) and lay it in the airbox. Squeeze the edges down so it is well seated
JSeaman
Derbyshire
C220 CDI 2005
Step 11 - Drop the air box back in, sliding the pipework together first
Step 12 - Note if you want a bit more room, you can depress the tab by the hydraulic rams for the bonnet and allow the bonnet to sit vertically as shown
Step 13 - Refit the clips on the air box
JSeaman
Derbyshire
C220 CDI 2005
Step 14 - Refit the clips on the induction piping
Step 15 - Pop the hose from step 5 back in place
Howard
CLS 500 / A 190
Mine doesn't look like that :(;)
But a comprehensive write up , agreed , good job !
