gummi pflege or krytox?
MissyD
Essex init
www.depop.com
E200 1993, E300 Coupe 2019
Been advised to get gummi pflege for my clk, but whilst I was looking, I found that people use Krytox, what do you guys think please? Thanks
Not much difference really Sarah IMO, I used gummi pfledge but heated it a bit before using as it's maybe a little higher viscosity
A.J.
Norwich. UK
My own preference would be Krytox having used it for about three years on my Eos. The reason for Krytox on the Eos ? recommended by VW. I did find it effective though, softened the seals nicely to give a nice waterproof seal. :)
I use gummi because it's a fair bit cheaper . I also occasionally use silicone grease on the top seal .
Chrishazle
Nr Ashford, Kent
Investigated this a while ago for the 968 cab, Krytox recommended by VW but horribly expensive, Gummi recommended by many places and a hell of a lot cheaper - so 1 guess what I use! Do the seals on the 968 cab and the C220 2-4 times a year and all is fine.
flowrider
SL500 (R230)
I use Gummi Pflege and i have no complaints.
00slk
Cambridgeshire UK
Buy a can of each :D.................
Craiglxviii
Cambs UK
Gummi pflege here. Does the 3D door seals on my CL quite nicely.
MissyD
MissyD
Essex init
www.depop.com
Thanks guys, just ordered a couple of sticks of gummi :)
mikestrivens
Stockport
do the seals on one side in Gummi and the seals on the other in Krytox, come back next year and tell us which leaked.
A.J.
Norwich. UK
MissyD
MissyD
Essex init
www.depop.com
gummi pflege arrived today, done the doors and the rubbers at the top of the windscreen, just got to do the rest of the roof. Can I stop the roof in mid operation without breaking it?
Chrishazle
Nr Ashford, Kent
I do with my cab Sarah - but it's not an MB!!:D:D
A.J.
Norwich. UK
I don't know about a CLK but I certainly did with my VW Eos with no harm at all to the mechanism, hydraulics or electrics :)
Yes you can Missy D . After a few minutes you get an audible noise that tells you it will start moving again , I just activate the roof moving button again briefly and it does another few minutes
Chrishazle
Nr Ashford, Kent
Now you've discovered the difference that treatment makes, you now need to get in the habit of applying gummi every 3-6 months (3 months if the car lives outdoors), so that spare stick will eventually be needed! I not only do the roof, door, bonnet and boot seals on my cab, I also do the door and boot seals on the S204!
