heated seats
slksimon
near york
2006 200slk
hi there,our heated seat drivers side has stopped working on the base,the back gets warm but thats all,any ideas anyone? regards simon.
racall
london
c class and slk
Slk heated seats are prone to failure and some need a new seat cover as the element is sown into the cover,
I,ve just replaced the backrest foam on a r170.not the easyest of jobs.
I believe the seat base is not as hard as the backrest.
HaydnM
Newark , Notts
Mercedes ML350 / W164
The words Replace / Replace / Replace come to mind, Talk to Matt32AMG, he will confirm
Sometimes it is possible to find the broken wire and replace it, I have the upholstery removing instructions somewhere
slksimon
near york
2006 200slk
that would be great if you could let me have the instructions regards simon.
slksimon
near york
2006 200slk
sorry,by the way its an 05 slk200 regards simon.
E mail address please
Alex Crow
Super Suffolk
hi simon, you will find the seat base has 3x seperate elements wired in series - so if one fails they all do. the two side elements are available without the upholstery, and not too expensive, so if it is one or both of these that has failed you can fit new. otherwise you may as well find the broken section (easy, find the burn mark in the padding) and repair it as the base center and back sections are extremely expensive.
5 Emails sent to you
slksimon
near york
2006 200slk
hi malcolm thanks for that,but mine is a 171 model,have you instructions for these? thanks simon.
Alex Crow
Super Suffolk
the last side element i fitted for the base on a 171 was £71 +vat - not cheap, but the other elements in the center base and back are fortunes as they are stitched into the covers.
I will print them off in the week for you
John Kerr
Nr Folkestone Kent
W209 CLK 220CDI Sport
Just a thought would the heated seats be covered under a mercedes tier one warranty.Reason I ask is my recently bought CLK drivers seat base dosn't heat up
slksimon
near york
2006 200slk
hi john, thanks for the suggestion but the car is 5 years old so the warranty will have run out.....unfortuneately,the car is costing too much on repairs in the short time i have had it!
aquanaut
Aberdeen
2020 C63s AMG
Should be, had the same problem with my C55 and merc tier 1 covered it
pomm001
leicester
SL 500 R231 A clas W169
In the same boat myself, having recently bought another SLK i tried the seats first and the base did heat up, but now tried it properly it just gets a little warm equal to #1 setting
Having bought from a non franchised dealer the best i could expect is to have a cheap after market heater fitted and properly begger up the seat base as well
Its not something that worries me too much but is annoying
If you do find the break in the element how do you connect the two ends
Malcolm any chance of any instructions on the cover SLK 171 57 AMG
many thanks
Alex Crow
Super Suffolk
...If you do find the break in the element how do you connect the two ends...
By soldering in a short new piece of suitable wire.
many thanks
Yes I have all the details to do this on the 170 and I can print off the same for the 171, give me a day or two.
