HELP! econ’d injector, engine spoiled up,white smoke cloud
Stampee
2003 220 CDI
sorry to ask for help on first post but I need some Advice please,
2003 w203 220cdi
Basically
After I changed the injectors engine smoked on start up badly and just well smoked in general, no power and lumpy noisy. Took to mercedes specialist , he said all the new injectors were bad. on the Short drive home all HELL broke loose, the engine suddenly spooled up, i pulled over and it kept running even when I turn the key off, stalled it by putting in gear and engine shut down, Huge cloud of white smoke, got videos of it too luckily. white smoke continued coming out of the exhaustwhen it wasn't running.
Head Gasket Blown?????
John Laidlaw
Wirral
Land Rover Discovery 4
Did you change the injectors yourself?
Botus
S500/2010/500
so all the injectors u fitted were no good....
refurb lot a bunch of animals? when the bloke said they were at fault he should have pointed out the risk.
don't get why mercs run on, take the key out should turn off the fuel feed to the injectors so it doesn't keep going
Stampee
2003 220 CDI
You’d think but guess till the fuel in the cylinder ran out and it just keeps going. Trouble is now do I spend cash on injectors from another company not knowing if the engines stuffed. Mercedes specialist did a diagnostic said they were crap injector. On route back it went out of control
joderest
ML270 2003
Check your oil level, it could well be the injectors have leaked into the engine badly, bringing the oil level up, the engine then picks up the oil and runs itself to destruction if you cannot stop it, lucky you were not an auto box.
I have witnessed this twice, once on a Motorway with a van, large bang in the end, and other was with a Landrover Defender TD5, of which the owner had already been warned.
I doubt the rubaway is directly an injector fault as the key will turn off the supply of fuel so an injector even stuck open will run out of fuel and stop the engine.
This sounds like diesel runaway (which may have as said above been caused by bad injectors dumping fuel in the sump) and causing the runaway indirectly.
Drain the oil, refill with fresh and restart it. If it runs OK for a couple of minutes stop the engine and sort the injector issues.
joderest
ML270 2003
It would all depend on how "out of control" it went before you stalled it. If it just rev'ed hard for a few seconds, and then was stopped, may well be all good.
Do as LOSTKIWI suggests, its good advice
Stampee
2003 220 CDI
Thanks all it’s much appreciated. I don’t think it was that long. I have a video of it. Though was a lot of panic dash views and more audio than anything else. Don’t think I can upload it though.
joderest
ML270 2003
Have you checked the oil level with dipstick ?, if very high confirms what has been said
We don't know how much was burnt off. Sniff it. If it smells of diesel thats the problem.
Westheath
South London
2003 w203 220cdi
Basically
After I changed the injectors engine smoked on start up badly and just well smoked in general, no power and lumpy noisy. Took to Mercedes specialist , he said all the new injectors were bad. on the Short drive home all HELL broke loose, the engine suddenly spooled up, i pulled over and it kept running even when I turn the key off, stalled it by putting in gear and engine shut down, Huge cloud of white smoke, got videos of it too luckily. white smoke continued coming out of the exhaust when it wasn't running.
What was the reason for changing all the injectors in the first place.
And why not return them to who ever reconditioned them or did you do them yourself ?
Stampee
2003 220 CDI
One injector has started with the Black Death. Another had been replaced at some points as was a bit mangled which had to have been a second hand one . So I decided to do all 4 with reconditioned ones as I though might as well do it right. I can send a video if anyone can offer advice.,it’s to big to load here or can what’s app it? Lots off clack clack clack , spooled up for about 8-10seconds . I shut it down using 3rd gear, white cloud and white smoke from exhaust after shut down.
Stampee
2003 220 CDI
  • #17
Been away for a few days .,will check oil tonight,,, should I go down the injector line replacement can any one recommend a Good company. PF jones?
Thanks again for all the help.
Dave
Stampee
2003 220 CDI
  • #18
This is a headache. Injectors 0445110174
2003 Mercedes w203
So car running Like crap and as I said took to MERCEDES SPECIALIST . I asked him if they needed coding and he said not for this car. The main reason I took it there was because I thought they did.
I spoke with PF jones today and they said yes they need coding., I’m stuck between a rock and a hard place. I originally took it to a so called specialist for coding? Then got a diagnostic instead . Told injectors. Stuck scratching my head in France not knowing what’s going on.
Also
Can’t smell any diesel when I remove oil cap.
