I haven't read the whole thread but think the problem is underfuelling, possibly a result of duff MAP sensor.
A customer of mine has a similar problem 03 merc 311 cdi no power, if you floor the throttle it will only rev to about 3000rpm, and is dead when driving, the fuel filter was replaced around 10 k ago, and my diagnoistic will not make contact with it, i've checked the intercooler pipes, and the turbo looks good. I'm thinking of trying to bypass the fuel tank and running it direct, but i mite check the wiring that you mentioned first. This is my first post here, looks like a good site.
Hello beam99,
Bypassing the fuel tank is worth a try,if possible try a direct feed to the injection pump. You will need to rig up some form of gravity feed in the cab or bulkhead.
Adrian.
Hello Sheepster,
Why you have the lift pump off,it might be worth giving the above a try,you have nothing to lose.
Adrian.
it also had black death to the brim of the rocker box as 2 injectors was blowing (noticed once I removed all the tar) so I re cut the injector seats, fitted genuine slight over size Bosch copper washers (instead of the ****ty Mecedes domed ones) and a complete set of recon injectors,
