HELP! Mercedes Cl500 W215, Battery Draining very quick!
jwhelancarpentry
London
CL500/2002/5.0-V8
Hello there,
I am hoping i can (once again) pick your brains, to try and understand the problem my lovely Mercedes is showing!
I have a w215, CL500 2002. Brilliant car, absolute beauty.
However..
If for example i drive to my Mrs's house, ill park the car on the drive, come to start it in the morning, and nothing. Flat as a pancake.
It is obviously a very very big drain, to be able to flatten a battery of that size over night!? I have done the simple things: turn wipers, lights off of Auto. But now I'm lost. However, previous to this. When it went flat before. I had the trunk open, and i could hear a ticking/knocking noise from the left had side in the boot. However i have not explored this yet. I do not know what it could be!
Any help, ideas are always very much appreciated!
Regards,
Jim
Lexman8
Yorkshire, The French Alps & Quahog
CL500 (2001): Distronic, Bose, Keyless Go; Honda CR-V EX (2011)
The pneumatic pump for the doors, etc, is behind the trim, top left in the boot. That's probably the source of the noise but whether it's the cause of the battery drain is another matter. Normally it would be a whirring/humming sound when running and usually only for a few seconds at a time.
In the attached pic it has 'MADE IN GERMANY' on the cover.
J
jwhelancarpentry
London
CL500/2002/5.0-V8
Forgot to mention
Hi there, thank you both, for your replies.
I forgot to mention, i am currently using a spare key, which is not a keyless entry one. The keyless entry warning sign, is forever coming up on the dash board. And sometimes, i have noticed the Mercedes dash board being illuminated, with the keyless go warning on the dash. Could that be the drain?!
Cheers lads,
Jim
Cheers lads,
Jim
No, as the cluster all goes dead once the car is closed and locked,
