Hi folks new to this I hav problems with 230 kompressor slk roof
Ewan Gibb
230 kompressor
Hi I hav problem with my wifes 230 kompressor slk roof won't go up or down hav tried another switch but still doent do anything if u flick it both front windows go down but nothing for to activate the roof I need help plz
grahamcol
West Midlands
2001 SLK230, 2007 CLK220 CDI
Best thing to do is get it to a good Merc indy with Star diagnostics. Don't go to a main dealer.
E
Ewan Gibb
230 kompressor
Thanks I have been looking at al sorts of stuff on you tube and hav my local electric man look at it and he' no sure am in the Scottish Borders so am no sure whare to go
E
Ewan Gibb
230 kompressor
Hav had my local electric man look but he's no sure am in Scottish Borders and not sure whare to try that's no going to cost me my arms and legs
E
Ewan Gibb
230 kompressor
Hi am not sure if am doing this write as can' see any replys or that
There's s relay in the boot that can fail (at least there was on the Wheeler Dealers when they had an SLK).
E
Ewan Gibb
230 kompressor
Yeah hav seen that episode but my electric man has checked that any other ideas thanks
E
Ewan Gibb
230 kompressor
I believe it does but can' totaly confirm
You should be able to hear it when you operate the switch.
mercedes13156
West Lothian
CLK 200 Cabrio and a Ford Kuga
Hi. What year is it? If it has the 16 pin socket, I have an iCarsoft 980 which gives me a full live data readout of every component in the roof of our 2003 CLK convertible.
I see you're in the Borders but if you're really stuck, I'm just outside Edinburgh near Livingston and do free diagnostics for fellow forum members.
Julsm
Belfast, UK
www.facebook.com
SLK 200 2006 (R171)
Hi All... I too have a roof problem!!
It's been about 3 years since I was last on here, but I'm back with a problem! ;-P
My 2006 SLK 200 (R171) roof is giving a bit of bother. It's the rear passenger side quarter-light which sometimes won't open.
It seems to work when the car is cool in the morning, but once the sun shines on it, not a hope!
I left it in with a local garage a fortnight ago and they put it on the computer saying it needs a new window motor.
But it's worked every time since they had a poke at it, so I'm wondering could it be a bad connection?
Or is there a temperature sensor? It's starting to play up again now in the lovely weather...
Any advice before I splash out on a new window motor kit?
(It closes every time without a problem!)
Juls M
John Laidlaw
Wirral
Land Rover Discovery 4
Might be a faulty relay/ bad connection by your description of heat effect - check the relay first which I believe will be in the boot somewhere ( not too familiar with the SLK but there are plenty folks on here can advise better)
sturge
Surrey
SL 500 R230 Black Beauty, Vito Brabus Sport X. Old Merc's CLK Kompressor E230 elegance E220 co
I’ve got an SL with the same problem. Have you checked the window rubbers? Sometimes they stick to the glass.
Julsm
Belfast, UK
www.facebook.com
SLK 200 2006 (R171)
Yes I've checked the rubber seals.
Thinking it's electrical or a relay... where in the boot would they be??
John Laidlaw
Wirral
Relay is behind a panel on the right side of the boot
