High beam assist
Jimbo1959
Ayrshire
VW Scirocco. The Quattro, E350 CDi Blue Efficiency Sport Coupe, now both gone
Spurious reasoning.
My car and my wife's car (and I'm sure yours as well - been on MBs for a long time) have a 'P' position on the light switch....Select P and push the indicator to the side you want parking lights - Ignition off - why wouldn't you use this?
If you are parked then you should be able to turn off your ignition 'most' of the time......seems to me you are 'cutting off your nose to spite your face' as you would benefit from your ILS more (in your general daily driving) than the 'inconvenience' that you have for the times when you are parked facing oncoming traffic (which is apparently illegal at night) and don't want to turn your engine off.
How so spurious? I am only practicing consideration for others. Yes my car has the park facility and yes I do use it, it’s the OP’s I am having a go at who don’t think or consider the possible consequences of their actions. I do not want to switch off my ignition/engine because the electric heated seats, blower motor and infotainment system all draw a fair bit of power from the battery and don’t work without the engine being on, plus, I’d rather be comfortable than freezing my ass off in the depth of a Scottish winter. I guess I’m just a “control “ freak
rorywquin
North Yorkshire
An old B-Class.
You are making an irrational argument for not using ILS.
Can you not use position 5 - when parked, facing oncoming traffic, at night with your engine running & switch back to auto for the other 99% of the time you are using the car?
Exterior lighting
ajlsl600
france
hear you. but where i can ,i am avoiding the throw away system that prevails today, i get you ref trying lights. my point, why bother, i am happy enough with what i have and dont really want to go LOOKING for something else i did not know i need.
Jimbo1959
Ayrshire
Each to their own Jim. I leave mine on Auto everything, just makes life a little easier and lights come on at the right time rather than you forget them :rolleyes:
When I first got the car I did too Andy but, I didn't like the fact that you could only override the system by switching the ignition/engine off.
Basically as soon as you switch the engine on, the car decides what lights are required and when, if you had the switch on the off position the lights would still come on if the car decided the ambient light level warranted it.
I like to be able to control and decide what the lights are doing when I want them to do it.
I never forget to switch my lights on, but, as you said, "to each their own".
Craiglxviii
Cambs UK
That choice is now being taken away by regulation. No more Off position. There is On or Auto now.
Jimbo1959
Ayrshire
Exterior lighting
It is your opinion, that my arguement is "spurious," :-(of a line of reasoning) apparently but not actually valid", and irrational.
You use and are happy to use the ILS system.
I am no longer happy to use it because it removes an element of control which, I prefer to have at my fingertips. As I mentioned in an earlier post, I admit, I am a bit of a control freak.
On my car you programme the operation of the lights with the onboard computer and they, as a result, come on, if the computer, upon checking the ambient light quality, deems it necessary, as soon as you switch on the ignition.
If the light quality is such that the computer decides the lights should be on there is nothing you can do to switch them off, using any switches at all, you must switch off the ignition/engine to kill the lights.
However, If the daylight is bright enough, they will auto cancel.
This operational configuration can only be overridden by programming the onboard computer.
This is what I was trying to explain. I thought it was a perfectly valid point.
My light switch bears little relation to the figure you have posted however, that's mainly down to one function and positioning.
I can, now that I have set the computer to do so, use my lights in the manner /fashion you have illustrated and explained and do so when I want to.
I am in control, the lights do what I want them to, when I want them too. Ultimately, it is my choice.
We are all individuals, with our own little foibles and ways of doing things, I could not say your way was spurious because that is your choice, and not mine.
I feel I am experiencing deja vu, let's just agree to disagree, (again). Good day sir.
Jimbo1959
Ayrshire
Thank goodness I won't ever be in the position, financially speaking, to buy a new car where, I can't switch something off. Regulation has gone mad.
Craiglxviii
Cambs UK
No, it’s there to keep people safe from those who like to reprogram their vehicle lighting systems to act in a manner other than designed.
I’m off to reprogram my ABS so I can get a bit more of a skid going when sideslipping onto the A14 ;) :D
Jimbo1959
Ayrshire
I'm getting out of touch with what can be done to cars these days Craig, I didn't know that either of those functions could be "modified" :D
I guess special tools (software?) are required? ;)
Sideslipping?? is that the new term for drifting? o_O:D:D
rorywquin
North Yorkshire
An old B-Class.
And for the idiots that drive in the dark without lights.......
rorywquin
North Yorkshire
An old B-Class.
I assume you are still running 'round dial' instruments in your aircraft (assume the machine in the pic is yours) and would never buy a glass cockpit ;).
PS what is it?
rorywquin
North Yorkshire
An old B-Class.
There is a button to "disable" ESP in my current and previous MB.
Probably not it smart to use it but, if the driver wanted to be "in control" the button could be used. :)
rorywquin
North Yorkshire
An old B-Class.
That's partly thefault of the idiots that design cars such that the instrument lights come on with the ignition instead of the lights like they always used to. ;)
I guess we can always find someone else to blame instead of being responsible for what we do. ;)
Andy.M
Rochester Kent
2014 GLA250 Premium Plus, Night, AMG Exclusive Leather, Driving Assistance Packs COMAND DAB HK Audio
I think that plays a big factor where cars in town set off without their headlights on. The street lighting can be good enough that you dont realise your headlights are not on because your brain is telling you the speedo is lit up so the lights are on.
ajlsl600
france
PS what is it?
its a rockwell commander 112tc.and no i wont be going for a glass cockpit .very happy with my instruments .only additions digital fuel flow ,transponder and gps otherwise all origional. watched a utube on harriers in falklands yest his glass cockpit went black at a most inconvenient moment, could have killed him .no thanks.....
Jimbo1959
Ayrshire
I think the driver would more likely be out of control if they did that, you're probably right about the "not smart to use it," I ask you, who disables a function which helps the driver stay "in control"? Certainly not I.
