Instrument backlighting not always on is this a fault?
oldham
s class
My Instrument backlighting not always on is this a fault? 1st time I noticed it not lit up was driving back Mercedes service after having the auxiliary (stop start) battery replaced under warranty due to a malfunction error flashing up on the dash, it was off then lit up a mile or so into the journey home. Since then it is sometimes lit, sometimes not. It's alway ok at night so maybe it's supposed to be like that and has a sensor.
jp williams
Wirral & Axarqia,Spain
2002 E class 2.2 cdi auto estate, Lexus GS 450h
Have you checked to see if the lighting switch has been turned down.It is usually a thin stalk like rheostat switch which needs to be rotated clockwise to increase the brightness.
D
oldham
s class
Thanks. I'll look for that but I think that's not going to be the issue as I'v noticed the lighting just come on as I'm driving along without me changing anything.
The numbers/dials only light up when the headlights/sidelights are on.
D
oldham
s class
Car is a 64 plate E Class with automatic (always on LED) lights.
DRL are on all the time
headlights turn on when its dark.
Dash back lighting only illuminates when its dark
D
oldham
s class
It could be that's the case. Just that I've noticed them coming on during daylight. Maybe the ambient light sensor seemed it to be dark.
There should be a dipped beam logo on the left hand side of the instrument cluster that comes on at the same time. (underneath the temp gauge)
