Is there a diffence between MAF cleaner and EGR Cleaner?
John77
E200 Estate 2011, 2009 SLK 200
Hi I want to clean the MAF sensor. I have some EGR cleaner but not any MAF cleaner at the moment. Is there a difference?
I read recently that they were mostly repackaged carb cleaner . I'm not saying that is correct though , but I work in that assumption by using carb cleaner :D
J
John77
Thank you.
Rob76
Coventry, UK
S211 E280 CDI Sport
EGR/MAF/Brake Cleaner - its all the same; high solvent content and no oily residue ;)
J
John77
Thank you. Also while on this subject where is the EGR? Do I need to clean it? W211 E200 2005. I have just seen a video on youtube and a guy is using oven cleaner. Surely this isn't correct is it?
Rob76
Coventry, UK
S211 E280 CDI Sport
Your EGR sits between the exhaust and inlet manifolds - but i dont know where - I cant point mine out yet!!
They do get quite clogged up over time so you wont know if it needs cleaning until you take it apart: but if it aint broke - id leave it.
I have heard oven cleaner being used, it would certainly get it clean - but i wouldnt!!!
J
John77
thank you
In general MAF cleaning with a solvent is a waste of time and money.
The MAF is a hot wire sitting in the air stream and over time they build up a crusty residue on the outer surface. A solvent will rarely if ever remove it.
On some cars there is a diagnostic capability to superheat the filament to use heat expansion contraction to crack the residue off but that in itself is a fairly kill or cure cleaning technique as the increased heat can cause it to fail.
Rob76
Coventry, UK
S211 E280 CDI Sport
And then you get charged for a diagnostic as well
J
John77
Thank you
J
John77
Thank you
J
John77
Ok So if I want to clean the MAF and EGR where are they on these pictures? Also does anyone have to service sheets for removal of these?
