Jacking padd recomendations for 2007 c class estate 2007
cougarking
cambs
220 cdi estate
Hi
Looking for reconditions and supplier for jacking padd for
C class 2007 estate
Wish to remove all wheels one at a time and use a trolley jack rather that the sissor
One supplied, so need a padd to placing trolley jack
Car is w204
Thks
An ice hockey puck works really well on top of a trolley jack
I just use a piece of wood!
Naraic
2005 CL500.
A "padd" (sic) can be bought on Ebay.
umblecumbuz
Wales and Gozo
I use two pieces of 15mm ply that sit on my trolley jack, one glued on top of the other. The topmost piece has a cutout in its centre that neatly fits the size and shape of the car jacking pads. Nary a slip.
If I use the ply for any other car I just turn it upside down on the jack Simples.
Submariner1
Windsor Berkshire
CL500 2009 5.5
If you want to use your jacking points correctly use these. I have been using them for years:
http://www.ebay.co.uk/itm/Mercedes-...ng-Pad-Rubber-Tool-also-fits-BMW/272808274127
I have four of these.
Fit the slot perfectly, and have a protective overhang. They sit inside my trolley jacks claws so can slip out and ensure the claws cant touch the cills.
The std. jack with the car is woefully scary!
IMO for a car that cost £96K, MB should have incorporated a modified 4T Bottle Jack and a plate to accomodate soft ground.
L John
W204 C350 Petrol Elegance
I take it you will be using axle stands for all corners.
ajlsl600
france
same as that .remember some yrs ago one cud buy a bag and put on exhaust to lift car,thought that a good idea ,dont see them now ?
.....remember some yrs ago one cud buy a bag and put on exhaust to lift car,thought that a good idea ,dont see them now ?
I had one at the time. It worked OK the couple times I used it. Fire service use (or at least used to) a massive version for helping right tankers where there wasn't anything much substantial to jack up against.
ajlsl600
france
yup. pity they no longer avail . i know this is a little old fart... but i seem to remember whilst an appretice seeing a ,i believe riley car with electric jacks in chassis outriggers and a little dash door with 4 switches in . now yr lucky if yr shixe jack dont collapse whilst jacking up yr car.....progress ?
+1 for these pads , I have had two for a few years now .
umblecumbuz
Wales and Gozo
My ole dad had a Ford V8 Pilot.
It had four hydraulic jacks underneath. Each would lower independently as required.
Clever old Ford.
The downside was, the engine was a heavy old side valve flat head V8 developing about 5hp, and mated to a three speed manual box. Oh yes ... and no brakes worth mentioning.
EXMERCTECH
Sutton,Surrey.
C320 V6 Diesel 2005
They did it's called Mobilo.
Chrishazle
Nr Ashford, Kent
Beware using just an ice hockey puck on a trolley jack, if the puck does not fit inside the claws of the jack. Pretty sure that was part of the reason my 968 fell off the axle stands when lifting the other side of the car. I now have the type mentioned above (that fits into the slot) for the MB.
M80
Derbyshire
and chock the front wheels if lifting the rear wheels off the ground.
