K40 fuse and relay box on a W202 C250TD
silestanix
London!
03' BMW 325Ci
Hi all, as per title I'm after the location of the K40 relay box... I have a feeling it's the normal fuse box but I'm unsure. Reason is the headlamp wash wipe system plugs into a connector in there and a relay has to be plugged into a certain location too.
So, any ideas which of the pictures it is??
Cheers!
silestanix
silestanix
London!
03' BMW 325Ci
Brilliant, thank you mate!
star
Reading
Smart + others :)
I would have said 2nd pic, under screwed down lid.
silestanix
silestanix
London!
03' BMW 325Ci
Ahhh... now I'm confused haha
silestanix
silestanix
London!
03' BMW 325Ci
Even Google seems to vary result wise... Hmm.
silestanix
silestanix
London!
03' BMW 325Ci
Cheers @brianbrian !
There's a twist though, so I looked on the WIS print out, and it's K40/2... Which is the fuse and relay box!
Never simple is it!
As star motor service said, take the cover of the fuse box, then you can undo the screws, so you can take the relay cover of.
Star is correct. I was getting confused with the N10 on the 129.
silestanix
silestanix
London!
03' BMW 325Ci
I need your help again guys... So, this is the instruction from WIS for the headlamp wash wipe installation...
' insert cables and connector into K40/2 Relay and fuse box, insert connector socket 6, fuse in location 45, and relay in location 6'
Only issue is, this is my relay and fuse box, it's different! I have no connector slots or socket for any relay...
How can I wire in a feed for the headlamp wipers? Regarding the Headlamp washer pump I may connect the headlamp pump to the windscreen pump so they both operate (not an issue tbh), but the wipers are an issue.
Any ideas?? I'm going nuts trying to figure this out! Thanks!
silestanix
silestanix
London!
03' BMW 325Ci
It's the one above 38 pin plug, Harry.
Cheers Andy, I can't find the location to plug the loom and relay in so I'm gonna the and wipers etc, basically fit everything that works and then build a loom myself next weekend when I'm off...
I think that diagram is for a different year of fusebox.
The 202 had a change of fusebox design 1/12/94 then again 1/6/1997
silestanix
silestanix
London!
03' BMW 325Ci
Mine is... Gimme a minute, I'll find the picture of my logbook on my work computer...
silestanix
silestanix
London!
03' BMW 325Ci
21/03/1997... Would this retrofit be on WIS for my year? I haven't got WIS :(.
I just need the Headlamp wash wipe retrofit, everything else seems fine to just plug and play.
silestanix
silestanix
London!
03' BMW 325Ci
  • #19
Ah no wonder, yeah it says as of 1.8.97... :(
