My C Class was laid up for 4 months - ther only problem this caused was that the battery failed. I would suggest putting a charger on the battery to keep it conditioned.
I was always advised to raise the car on axle stands to take the pressure from the tyres. As joem advises a trickle charger will keep the electrics happy.
Is the storage place heated and ventillated? You might get a mustiness in the interior in damp storage areas.
go to lots of trouble, supporting the weight of the car off the tyres by jacking up the axles a bit, clever application of polish to the body and a very long list of other jobs which others will know far better than me, or
Dont lay it up at all, just use it very occasionally. I have a 1972 350SL which I only use in good weather, it does well under a 1000 miles every year but it never stands for more than two weeks. Even through the winter I give it a run on dry days, a minimum of 5 miles. I personally think is far better than trying to mothball it for the winter. If nothing else it means that engine, gearbox and axle oil gets spread around and protects the units far better then any other option I know.
Mark.
PS, only thought after the post: The car lives in the garage, I always leave the drivers window open and during the winter the boot lid open as well (I take the boot light bulb out)
Thanks for the response and yes the garage is dry, not heated but no damp whatsoever, given the space available down one side I will not be able to 'raise it on axle stands' Mark, I totally agree with the point you make however I forgot to mention that I will be some 12,000 miles away so that will be a tad difficult, I have no one who would 'take it for a run' for me.
I seem to have read somewhere that it is better to set the alarm, not required from a security point of view given the setup I have, but setting it does reduce power drain any thoughts?
Mercedes-Benz Servicing, repairs, engine and diagnostics Wayne Gates - Mercedes-Benz, Unit F3, Phoenix Industrial Estate, Rosslyn Crescent, Harrow, Middlesex, HA1 2SP Tel: 020 8863 9233 Established for 20 years all vehicles washed and vacuumed.
