ajlsl600
- Nov 18, 2013
- Location
- france
- clk3202001,sl6002003 with everything regrettably sold ,A class 170cdi auto. NG/TF1800 ML250
Just fit a pre lube system, job done about 400 usd. System catches oil at pressure when running. Stores it in tank behind solenoid and releases it at next key to ignition on, the pressurised oil then runs around system as description. Pre lube. However it does not store oil at above existing running pressure so if ur system is about goosed it's of no real value. However if ur opp system runs at 50psi, that's just about what it releases next time. About 700ml at 50 psi shud if o rings not shot, pressurise tensioner fill filter housing and push some oil thru bearings. It's to f cold to mess about but I guess I might as well fit the one I have to ml or even classic. Better than sitting in a box.
