Mercedes Atego Cab Tilt
Rich_Allen
Atego 18T 2001
Evening all....
After some help, I have a 2001 Atego horse lorry that I need to tilt the cab to get to the engine.
Both hydraulic locks are released but the cab only lifts a few inches then stops and the pump goes hard and you struggle to push the bar down.
Have I missed something to release it?
Cheers
XJ600
Kentshire
2011 S204 220CDI Auto
Evening all....
Cheers
Have you opened the valve ?
R
Rich_Allen
Atego 18T 2001
Yes, Valve seems to work opening and closing... Set to open the cab starts to go up and then just stops. Pump goes very hard as if there is big resistance..
Last time the cab went up the pipe between the two locks split so they are currently disconnected, The pump is direct to the cab ram. I need to raise cab to fit new pipe etc.
Ken_R
Worcestershire, UK
W203 2006 C230 Estate
Have you opened/raised the front grill panel? Not sure if it applies this model but certainly many others.
www.ckinsurance.co.uk
