ml270 cdi - dip / main beam issue
Hi All,
We have a 2003 ML270 cdi standard RHD UK spec with 57k on the clock.
When the lights are in auto mode the lights randomly select main beam and then back to dip. you can hear the relay clicking as it randomly 'flicks' the lights.
So i replaced the relay - no difference, I replaced the column switch assembly - again no difference.
What else can it be ??
Every other electrical items works and there is nothing showing up on the STAR diagnostic.
I have removed the fuses for main beam for now to stop this occuring - but with MOT looming - i need to get this fixed.
Any comments / suggestions welcomed with thanks.
I will let you know if and how I solve this one.
Regards
I would turn the option off first and try it
Xtractorfan
S class
as malcolm suggests and u dont need to use auto for testing the lights
colechelle
Resigned
If memory correct the AAM All Active module controls lights wipers and just about everything ease, would put it down to that being u,s, changed one the other day for no locking and no front fog lights!!!!
H
thanks colechelle.
a few simple questions :
1) where is the AAM loacted
2) how easy is it to replace - plug n play - or is it more specialist
3) whats the approx cost for the unit
thanks in advance
panason1c
Somerset, UK
The only question i can answer is #2.....the AAM is not plug and play, it needs to be encoded to the car.
colechelle
Resigned
No worries Hampshire jock, under bonnet n,s your find the fuse box, remove lid, then remove the frame around cover, remove the screws in center of fuse board and lift out fuse panel, hanging of the bottom of the fuse board is the AAM, couple lift up clips and slide the unit off, is very easy but as Panason1c quiet righty pointed out it do need star to code into car, you might be lucky and find a lot will work or there again you might end up with knowt until coded!!
Tel: 020 8863 9233
