My Merc C Class voice control only does navigation
stevejwaterfield
C Class 2015 Saloon 2.2d
I just bought a 2015 C Class Sport 2.2 Diesel.
When I activate voice it just goes straight to sat navigation. That works OK.
Bit I cant seem to get telephone or music etc. It just doesnt seem to be there.
Can anyone advise me on this. I am not particularly technically minded.
thanks
Srdl
Hampshire
GLC43 AMG 2018 (X253)
Does Navigation work on voice control? Most cars of that era have the voice button but not the system to go with it. If it works with Nav, then it should work with the others - but it’s a ”stupid” system that requires very specific phrases.
Here is a link to some instructions:
stevejwaterfield
The navigation works OK. But I cant get it to do anything else. As soon as I press the voice conrol it switches the screen to navigation and puts up a slection of navigation commands. But if you asks for telephone or music or whatever it still goes to navigation.
Larkone
NW Essex
C219 CLS 320CDI 2008
If you only have the Audio 20 system I believe that only does commands for Sat Nav. You need a full Comand system for Linguatronic to work on all functions. Try entering your VIN into a Vin decoder to see which system you have https://www.lastvin.com/
Srdl
Hampshire
Does it work if you have the Music or Telephone screens showing first?
stevejwaterfield
Thanks Srdl no it doesnt make any differnce if I have Music or Telephone on first..
Thanks Larkone Yes I think it has the Audio20 system..
Can that be upgraded easily?
Steve
stevejwaterfield
Sorry I meant upgraded not updated.
Steve
Larkone
NW Essex
Steve
Upgrading anything from supplied on a merc is expensive and complicated.
These guys are the go to company for such things
Srdl
Hampshire
Steve
Can be done but not easy and certainly not cheap.
In my experience Linguatronic is pretty useless because it has to be such a specific phrase. It is certainly nothing like Siri or other voice activated systems. I have tried it once or twice but, in the end, I always find it quicker just to use the menus in the normal way. Personally, I don’t think you’re missing much!
stevejwaterfield
Ok Thanks Srdl
That all makes sense.
I have to admit that its a bit of a shock that my cheap old Suzuki had all the voice commands but the posh Mercedes doesnt!
But it is what it is!
Looks like I will have to live with it then.
thanks for all the advice
cheers
Steve
sug
w205 c200 2017 2000cc
I don't think you are missing much either. The Sat Nav is very poor and sorely tries my patience. Never tried it for music. The Parktronic has only worked twice in 5 years-something else I've never needed.
Whilst better than the R172 before think its Toyota or Lexus next for me
mercmancdi
templepatrick - co antrim
www.schnauzersinireland.com
2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
Not worth it you will never recoupe any money , is it garim where maps are on card. I have bought a few to upgrade maps for around £25 works great and has speed camera alert etc. worth it to bring maps up to date.
stevejwaterfield
Thanks mercmandi-thats a good tip. I live in London which is speed camera crazy!!
I try to keep to ther limits but a lot of the limits are nuts.
keitht1958
c220 cdi estate
thanks
I also have same problem just bought 2021 c220 amg voice button takes me to sat nav voice commands does nothin pretty sure it is command because I get command message when 1st starting vehicle
tried to check in using https://www.lastvin.com/ error not on database
is it possible to get voice commands working
I also tried merc me that just gives me weather and internet radio
Srdl
Hampshire
I would have thought a 2021 car would have MBUX which should have the full “Hey Mercedes” voice capability. Have you checked your owners manual for guidance?
EmilysDad
Bury Lancs
ML350
I gave up with the voice commands on my 14 plate ML a long time ago .... just easier to use the dial & the screen :)
keitht1958
c220 cdi estate
seems I do have MBUX i had to turn off car play then Bluetooth worked but only the voice button
hey Mercedes did not respond but I need carplay for WhatsApp
seems I cannot have car play and Bluetooth at the same time
Srdl
Hampshire
Have you tried this?
keitht1958
c220 cdi estate
settings have no voice assistant or Linguatronic options I went on Mercedes online c class 2021 but they mention Linguatronic which I can't find if I use the steering wheel voice but then my commands work on nav and media if I hold the voice button for 3 secs beep then it says mobile voice active
hey Mercedes does not work.
www.W140.co.uk&www.r129.co
