Submariner1
- Sep 3, 2016
- Location
- Windsor Berkshire
- CL500 2009 5.5
working under the car .. when it started to rain, as I moved one of those 350w lights I clipped the bottom edge of the wheel arch liner.
The case must have been scorching hot, as it created a sort of dented mark 4mmx 3mm where it almost melted/went through in a 2mm x 3mm hole.
Its just on the edge at the bottom corner, as it sweeps back under the floor of the car.
Magnified view ... its not quite gone through.
So I wondered what was the best thing to fill up the dent with before it becomes a hole.
I do have some araldite , but Would araldite stick to it? ... if it would, then a blob would do the job.
Or would black silicone sealer be best?
I do have some gel superglue for rubber and plastics, but I dont think it would stay bulky. But maybe use a course file on an old bit of ABS plastic to generate some shavings, and then make a paste with the dust and superglue.
Of course it would be on the bulkhead side, so dont think a hole would be too clever
On the other hand I guess water does track behind these liners, due to forced air etc. So maybe it doesnt matter.?
