Noise after switching on ignition in w126
alkanomega
1987 500SEC, W126 and 1984 manual 280SL, R107
Hi, I'm new here. Any advice would be appreciated. There's a whirring noise coming from around the base of the wipers with a regular click every few seconds, when I switch the electrics on, before I start the engine. It continues with the engine on, and you can hear it when driving, especially when stationary. Any thoughts? No obvious malfunction. I'd post a video with sound, but I can't get it to accept the file. Car is a 1987 500SEC. Thanks for any suggestions
Ben
Sent from my SM-G935F using Tapatalk
star
Reading
Smart + others :)
It could be the duo valve with aux pump working. Switch off heater fully and see if it disappears.
A
alkanomega
I'll try that. Thank you
Does the wipe clean OK and work on all functions.
A
alkanomega
It seems to
I see that the heater blower could be at fault, but these seldom move.
A
alkanomega
Wiper functions all OK. The whirr disappears when the cabin air (left and right) is switched to blue/cold, so I guess that switches off the hot air pump? Clicking is intermittent it seems, but reading around it I guess it could be the duovalve. The cabin heats up just fine, so the hot air is getting through. Need to see how easy it is to get at
Sent from my SM-T715 using Tapatalk
star
Reading
Smart + others :)
Duo valves do click on/off to regulate heat.
ianrandom
Berks & South Devon.
1986 420SE, 1990 420SEC, 1989 2cv6.
The valves do click but dont whirr that I know of. I would think the pump below them (aux pump to keep the coolant flowing?) is being a bit noisy.
star
Reading
Smart + others :)
I wasn't sure if the pump was attached to valves or not. I think some are but I'm not sure if it's on 126's.
www.ckinsurance.co.uk
