Very possible. In theory, once a hydraulic tappet is pumped up it should stay pumped up; but as they get older the little tinkers leak down and have to be pumped up constantly. This isn't an oil pump on start up issue, but could be an oil too thin issue. If changing the oil doesn't work then there knackered, but it sounds a lot worse than it is.Might be the wrong oil for your engine .
No. It'll just sound like an old Lada and have as much power as an old mini 850. Pop in some new tappits and all will be well.thanks will try that, if it is the tappets is there likley to be a catostrophic failiure
