Noisy Engine on startup
mikehb
Wales
c240
hi
my 1998 c 240 has become very noisy on startup, a failrly loud clattering, subsides after about a mile and is fine until next day
could this be tappets maybe or something else
thanks
mike
mikehb
Wales
c240
Thanks, it gets an oil change every 9,000 miles ,its done about 5,000 since the last change, is there a solution if the addative doesnt work
Yugguy
Rugby, UK
C220CDI W204 Elegance Comand
What's the mileage? Oil pump could be getting tired so it's not getting oil to the top of the engine fast enough on start, when the oil is cold and thick.
mikehb
Wales
c240
thanks, its done 160,000
Remove the serpentine belt and see if the noise is still there. A bad idler or bearing in an ancillary can sometimes do this.
I wouldn't expect an oil pump issue on these at 160k.
mikehb
Wales
c240
thanks will try that, if it is the tappets is there likley to be a catostrophic failiure
Arudge
Cradley Heath
CLK200 2000 Kompressor
Might be the wrong oil for your engine .
Very possible. In theory, once a hydraulic tappet is pumped up it should stay pumped up; but as they get older the little tinkers leak down and have to be pumped up constantly. This isn't an oil pump on start up issue, but could be an oil too thin issue. If changing the oil doesn't work then there knackered, but it sounds a lot worse than it is.
Arudge
Cradley Heath
Just re read the OP posts. Yes, there are additives for this problem, not a fan of additives myself preferring to address the problem more directly, but I understand they work well, a bit like radweld for your cooling system.
Arudge
Cradley Heath
No. It'll just sound like an old Lada and have as much power as an old mini 850. Pop in some new tappits and all will be well.
