Oil leak turbo exit??? W212
Lingwood
Yorkshire
E320 2010 3l v6
Hi noticed a couple weeping leaks on what I think is the turbo inter cooler?
Car is 2010 bluetec w212
The main leak is on the alloy pipe as in goes down the front. There appears to be a joint there behind the colt hose.
I have also noticed a bit of oil muck on the main body of the turbo from the intake around a orange seal.
I have read this is sort of normal, oil is ok and these leaks are not showing as drips on my garage floor.
Can someone identify what seals I might by to change and if it is a reasonable change to get out the alloy pipe...it looks fairly simple?
There will be a small green seal available for it.
The pipe isn't too difficult to remove, but there is a small bolt at the front behind the radiator that holds the pipe into a bracket that's a pain to remove.
L
Lingwood
Yorkshire
E320 2010 3l v6
Thanks, yes seen the small bolt/screw and front but also saw maybe a bit trim that could be removed to aid access?
Any more detail on the name or codes for this seal? Is it main deal only or eBay etc?
I have just taken off the air intake section to get to the big orange seal and given all that a clean
I read that this oil is ok/should be inside and nothing to be concerned about?
Last time I had it serviced they mentioned it and only issue the mentioned was possible oil getting onto the multi rib belt?
Best to call MB and give them your REG. They will sell you the seal, its MB only.
Yes, the oil in the intake is normal, no problem there. The seal should be changed when its leaking though as the inlet port shut off motor is directly underneath it.
L
Lingwood
Yorkshire
E320 2010 3l v6
Thanks, is the shut off port the bit below the orange seal?
Is the shut of motor the bit I have heard about that requires loads of the engine to be dismantled to get to?
Yes that's the one. Its a bit of work to change!
L
Lingwood
Yorkshire
E320 2010 3l v6
Thanks will phone up MB and try to explain to them which seals I might need! I suspect they might guess?
So I need the big orange one and the green one (s) at each end of the metal pipe?
Yes, they will know, Try MB Grangemouth, they are a forum sponsor on here and will give good discounts.
L
Lingwood
Yorkshire
E320 2010 3l v6
Thanks will email it too far to collect. Can try my local MB abut still nearly 1hr away
I think I found the parts on eBay I have messaged to confirm
They will post if needed, very quickly.
L
Lingwood
Yorkshire
E320 2010 3l v6
£17 for all bits and free postage!
That is the large orange seal to turbo inlet, £2.25 plus vat, the small orange seal for pcv £4.25 plus vat, and two green o rings for metal pipe £4 each plus vat
That is an excellent deal !
L
Lingwood
Yorkshire
E320 2010 3l v6
Urgent help required!
I have tried to replace the green seals but can’t get pipe off but think seals not seated and car not running correct? Ie turbo leaking air?
I have changed the orgage seals ok
I cannot get the alloy pipe off from the outlet of turbo to where it goes down from car
Help need ASAP
L
Lingwood
Yorkshire
E320 2010 3l v6
Found the extra bolt in the next black plastic section and now the alloy pipe is out. The seal at this end was soft and saggy and you could see was passing oil.
Sorry I missed your other message!
I did mention that bolt though :) it hides well.
L
Lingwood
Yorkshire
E320 2010 3l v6
  • #20
now I k ow and read your message it makes sense thought you ment the screw fitting that holds in the folk clamp?
Anyway not doing anything else tonight, and glad I took time to review and not crack or or I might have had the whole front end off.
Looks like an easy rebuild and nice to see the problem and that new seals should fix it
