borisfilipov
- Oct 25, 2017
- 2007 Mercedes S 320 CCDI
- Thread Starter
- Thread starter
- #21
PCV = positive crank case ventilation....
law says an engine can't vent crank cases gases to atmosphere... basically must go back in the engine via the air intake system
a PCV valve helps manage this system...
there is a modified engine breather for your car - that's a part you played with on some of the orange seals to the left of the turbo... its has a mesh oil separator to stop the oil mist going in the intake system. This might be completely blocked and cause part of the issue you have (hence my first post saying to clean it) and not sure how or why - but on this engine it also connects part of the electrical / engine management system - that must do something to manage the flow of crank waste gases.
get this system wrong and it will cause high oil consumption... because there is massive air flow beneath the pistons and nowhere to go so it forces oil up past the piston rings in the wrong direction
each time the top half of the engine takes in 3 litres of air (on each revolution) you displace just as much beneath them... this mixes with the oil thrown around and you have to mange it !!!! pumping losses on a 750cc high revving bike engine (moving air about below the pistons) at 10,000 rpm involves 100bhp just to get to those revs... to get any to do something useful it has to make a lot more on top of that first wasted 100bhp.... piston engines work hard and move shed loads of air
old oil also causes the breather system to struggle (don't know why but they do), if you do an oil change and then test the exhaust gas emissions it goes down... many a car would pass MOT after an oil change, when was a failure before
from the way you wrote your first post I still don't know what your real oil consumption is....
mate thank u very much for paying attention . London - Dunkirk - brussels - frankfurt - vienna - budapest - beograd - sofia - varna ( Bulgaria ) 3.5 Litres . in France i added 1L 5w30 and after 500km i was asked for more . may be it burnt it . and when i got back i changed oils . now i dont have an idea how much because indont srive too much. but for the trip going back 3.5 to 4 littes for 3000km. i have one request for you . my ebglish not so good and i would like to ask u to speak with little less terms and little more understandable . in other words . having in mind what ive done : checked turbo - good , changed 2 orange seals that were broken , changed all oils filters ... what i have left ? i will deff measure compression . what else ? i was looking a video about oil cooler seals change . what else i can do mate ? i will look now the pcv in google . saying one more time , when idle car does not smoke . car gives a little grey to black smoke when revs are like 4000. other situations no smoke . just when kickdown and when idle with gas pedal at 4000.
