PHEV / EV Charging not achieving 100% capacity (not range!)
tivechase
C350e, 2015
If you have a EV/PHEV do you manage to achieve 100% charge via your 3 pin cable?
My c350e struggles to get over 68% using my 3 pin cable. (The fast charger gives me 100%.) Someone at the dealership told me it would only achieve a 100% charge with a fast charger home unit. I'm not convinced by this.
This is not a question about the charging range but the percentage the battery charges to.
Cleck
Wakefield
EQC 400
My mate has a 350e and charges it using the three pin cable. It is plugged into a socket which is on it's own 16a ringmain and it charges to 100%, which equates to about 15 miles.
T
tivechase
C350e, 2015
Thanks. What does this mean? Is this a regular home socket or was it adapted for charging use?
Cleck
Wakefield
EQC 400
It just happens that the socket nearest the door is the only one wired to a 16a MCB in the mainsboard. It is just a standard 13a, three pin socket, but with no other sockets drawing any load from that particular supply.
It would be the same if at home you unplugged absolutely everything else and just had your charger plugged into a normal socket.
GlosRichCLK
Gloucestershire
If the fast charger gets it to 100%, then there's a problem with your 3 pin socket.
T
tivechase
C350e, 2015
I’ve tried two different plugs at different houses. The only consistent factor is the charger.
Redbluearmy
2017 C350e
I have a C350e and it achieves 100% wherever i charge it. On my standard cable plugged into a socket (Home and work) or my home charger on the wall. Hope this helps.
T
tivechase
C350e, 2015
It does. Thank you. Out of interest, how long is a full charge taking on your 13 amp home socket?
Redbluearmy
2017 C350e
13 amp home or work socket usually takes around 4 hours on average. Around an hour and a half for my home charger on the wall.
Marshall13
C350e
Hi, I only registered to say I think the range you get on a full charge is a load of crap. I've had the car a year and whilst I bought it due to company car tax savings and the fact that there aren't many cars that do 0-60 in less than 60 seconds for the aforementioned Co. tax band, the actual range available is really poor. I once saw it register 18 miles, which in reality is about 12, but for the last 6 months, I've never seen more than 14 miles, and if lucky that equates to 8! It really is that ****. I see MB are still claiming around 31km on a full charge which is totally misleading. I based all my decisions on the fact that I would save a load of tax versus my previous BMW 520d and that my fuel bill would be a little bit more, but it's just nowhere near what I was led to expect. If this loss of battery power continues, I won't be able to start the ****** thing in another 12 months.
If you are in the position I was in 12 months ago...think very carefully.
It is pleasant to drive and good fun when you floor it, but the underlying **** off factor around doing just that is that the fuel gauge moves at the same speed as the speedo.
