Prop centre bearing
Hi all
I changed the prop center bearing whilst I had the old one out yesterday.
Today I have this noise:
https://youtu.be/6mF6FqFh03M?t=50s
Is the replacement (febi) bearing faulty?
  • Moderator
Keep in mind I also changed the gearbox, so this new noise could be from the box.
DREAMER NO2
W124 2.6E M103 1989
Alex only thing i would do , is remove the propshaft and try it again, to see if it is the one or the other. But as you know marking of the propshaft before removal , so it is replaced in the same place you removed it from Did you check the little bearing inside the coupling some you need to put grease on before refitting the propshaft Could be the speedo cable disconect that first and try it .
  • Moderator
Thanks, yes I marked up the prop before separating/removing. Also used the alignment marks themselves.
When you say the coupling, you mean the U joint? They seemed absolutely fine with no grinding or anything whilst off the car.
No speedo cable on these, all electronic.
  • Moderator
So its stopped doing it now. Lets hope it stays the same!
  • Moderator
Yeah, not a bad shout! This has holes on one side for the handbrake cable bracket so not possible to put it on backwards without having the handbrake swinging in the wind.
  • Moderator
All good today still, something banging on the underside on engine start though. Must check the exhaust is in the right place.
DREAMER NO2
W124 2.6E M103 1989
As we are talking about propshafts is it possible to replace the front propshaft coupling on the w124 m103 without taking out the whole propshaft? I have asked on the forum but get mixed reports .I need to talk to a member thats done this himself .
WG M-B
North west london
C63 Wagon in black
Yes it's fine. But bear this in mind....
You will have to force to push the propshaft back to remove the coupling . You should drop the centre bearing first!
WG M-B
North west london
C63 Wagon in black
And check the centre bearing carrier doesn't get damaged after
  • Moderator
Back again today. Seems to be temperature related. A cacophony of noises from 20 mph upwards. Very odd.
  • Moderator
Yes I agree, Need to take a look and see whats going on. Just have to find the time! Pah!
  • Moderator
Looked again today, no witness marks on the prop or the rear propshafts, or the underside of the car. Spotted a bit of grease leaking from the new bearing, but suspect its normal:
_Taz_
Kent
2011 E63 6.3NA AMG Tenorite Estate MCT 7g
I see the mounting holes are slotted, is there a reason for this to allow self alignment during fitting ? Never changed one... But wondering if the carrier is at an angle to the propshaft ? Just a thought !
HTH
  • Moderator
  • #19
HTH
thanks Taz, yes indeed, they are slotted to allow for installation without tension in the rubber carrier. When I installed it I left it limp and tightened it up again so there shouldn't be any tension.
  • Moderator
  • #20
Update. Ran it up whilst wheels where off the ground, and prodded around with a stethoscope.
100% noise is coming form the Meyle center bearing. Supplier wants me to remove it and send it to them so I can they can "test it". Its not likely I can remove the old one without damaging it. PAH! Will buy another and replace it at my own cost.
