R129 under bonnet insulation
chardF
Warwickshire
SL 1994 320 R129
Hi all
Mine has given up the ghost, crumbled and collapsed. Tired of having bit's drop on me when I'm checking the oil or whatever, I've pulled the rementents off. It came off pretty easily actually, just a couple of bit's left to scrape, a job for when the weather gets a little warmer.
Has anyone tried the SL shop version?
http://www.theslshop.com/mercedes-benz-sl-r-129-under-bonnet-insulation-1296802025.html
I can't imagine this item is much more from an MB dealer?
Any other suppliers or generic solutions used? I'm guessing it'll provide heat and noise insulation, mine is only a 320 so under bonnet temperatures never get all that high, does leaving it off make much difference?
B
brick10
That looks quite good to me, i replaced mine a few years ago, got it off e-bay for about £80, but that looks better.
B
brick10
It's a cr*p job anyway, but worthwhile, and has to be done.
That looks the same as mine. If so it looks good and nicely made too.
worldbiker
London
1996 SL320
Very easy. Good bit of kit from the SL shop. I did it - this is what I posted back in May 2015
"Not a 280SL but an 320SL (sorry). I bought a new insulation pad from the SL Store, together with replacement clips and spray on adhesive.
The old one came off pretty easily (spread an old sheet over the engine to collect the debris) and then used a stiff broom and blunt paint scraper to clean off as much as possible of the old glue and residue.
Sprayed the bonnet and new pad with adhesive, left it to become tacky, then hung it on the new clips at the front of the bonnet and then smoothed it down (like hanging wallpaper). All good and seems to be stuck like sh*t to the proverbial blanket.
The only PIA was removing the old clips, which was what I expected and why I bought new ones.
Hope that helps."
C
chardF
Warwickshire
SL 1994 320 R129
C
chardF
Warwickshire
SL 1994 320 R129
Another question, is 1 x 500ml aerosol of trim adhesive enough?
pancholi
1996 SL 500 , 2003 CL55K, 2004 E320CDI
sorry i have not got round to sorting mine out yet. as my CL 55K is a demanding Queen, so money gets thrown on her first :(
raj
C
chardF
Warwickshire
SL 1994 320 R129
Thanks, love that video, fat dad on a bendy bridge.:)
I think I'll order one and give it a go. My pad collapsed so I removed it, I think I'm noticing more engine noise now!
I'm thinking of a different technique. Dangle the pad from the bonnet using the press rivets, spray with adhesive, raise to vertical position then smooth down.
From when I had Range Rovers and had to glue the headlining back in I was never particularly impressed with spray adhesive as I found it didn't last long before it started sagging again.
I'd be more inclined to use a brush on product.
pancholi
any products you recommend?
C
chardF
Warwickshire
SL 1994 320 R129
C
chardF
Warwickshire
SL 1994 320 R129
  • #19
So stripped off old insulation and left with this.
Combination of scraper, drill and dremel with polishing pads left this.
Dangle pad from push rivets, spray with adhesive (500ml was about right)
Wait 10mins and smooth down.
Sorry about the rubbish photos, important to work quickly before Mrs F discovers where her curtains are. :p
pancholi
thanks for the pics and info..
where did you get the insulation pad from?
quality good?
cheers raj
sorry just read the previous thread : you got it from Germany... all ok re. delivery and quality?
