R230 Consumer Battery
nicholas15
near Ashford, Kent
s class w221 - 2012 350 Bluetec, SL500 r230 2003
Following advise here, I having invested in a CTEK charger for use on 2003 SL500.
My question now, is can I charge the consumer battery via the cigarette lighter or only via the terminals on the battery in the boot?
I presume it is an AGM battery?
ajlsl600
france
i just connected up the plug end cables to the batt and leave the lead poking out into the boot,i find that once conected its still no issue to close the boot. agm it tis. i also keep a ctek on the front batt ,tho i rotate that on SL,CLK dont know about fag lighter as input, someone surely will, seems best to me to involve going thru as little as possible to charge consumer batt .rules out ANY dramas
Only via the battery terminals.
Easiest way is to put a fixed fly lead on the battery and use that to connect the battery. The CTEK usually comes with a flylead with eyelets that will do the job. Yes it's an AGM battery.
McDonald
Surrey
SL500 2004
While my car is resting I use a Ctec battery conditioner on the consumer battery, but not on the starter battery. Am I just lucky that the car starts immediately every time?
Never had to charge the starter battery on ours. The consumer battery goes flat for fun though....
ajlsl600
france
my start batt went dead a few yr ago, it was 10. since no issue i just prefer to rotate the ctek now and then. mine spends 4 /5 months in its cot.
Denis O
Dereham, Norfolk
R230
I have a fly lead attached to both starter and consumer batteries in my 350. Most of the time the C-Tek is on the consumer but every now and again I give the starter battery a quick shot. It certainly won't do it any harm even if it doesn't need it.
N
nicholas15
near Ashford, Kent
Thanks. The consumer battery has eyelets attached from the previous owner so will use those.Thought I ought to do something because I will be in New Zealand over next couple of months
Also thanks to others for their comments.
Excellent! Which part of the country are you going to?
N
nicholas15
near Ashford, Kent
Typical tourist; fly into Auckland, hire a car, then Paihai, Stratford, (Forgotten Highway), Cambridge, Rotorua, Wellington, then bus for South Island, Christchurch, Trans Alpine, Fran Josef, Queenstown, Christchurch, Auckland
Guess much of that is familiar to you!
00slk
Cambridgeshire UK
Yep, been to all those places ;)
We just leave our car batteries connected when we go overseas, longest time left was 3 months and haven't had any flat battery issues. Hope I haven't said anything, I don't want any bad omens :eek:
