ajlsl600
- Nov 18, 2013
- Location
- france
- clk3202001,sl6002003 with everything regrettably sold ,A class 170cdi auto. NG/TF1800 ML250
well i get home,retired . take the sl off blocks after12 weeks. before i last left i did a star fault check ,just looked at it ,only one, related to alarm ,i know about this the batt leaked in it, i have a new one ,need time to fit it.
anyway ,lowered car off the blocks , sank on left front ,stop car too low warning , ok lift up and down 2x and seemed ok . now abc warning in white ,!!! put star on .. many issues not there before ,thought related to batt .car starts straigh no issues , no conssumer batt warnings so now have. drove car for three mile all seemed ok , command,ac, heater lights, windows all good just faults as listed and abc in white
B1639 components or signal cable to components S41 andS42 open or short circuit, current and stored . dash shows check colant
B1010 lower control panel supply voltage N72 too low and stored
B1088 instrument cluster not transmitting on can bus
B1829 fuse for starter battery is deffective
B1832 G1/4 starter battery is deffective
B1074fault can comm with N72b1106 can ocp
B1121 can command audio
b1467 heat exchanger shut off motor current and stored
any common denominator?????? batt 12.3 volt and been on ctek from and rear for12 weeks ,never any issues previously
during this
and now abc is at or seem full height and level but the ride height wont chage even tho the button shows the two lights,one light and no light .
these cars are a nightmare
also abc does not show up now in the quick test, it did the first three tests
during this
