r230 pse pump coding
Doc47
SL 300 2011
I am buying a new PSE vacuum pump but have read on this forum that it will need to be coded to the car. How is this done, does it need to be done by a MB dealer or can my local garage do it.
If your local garage has STAR then he could do it
D
Doc47
SL 300 2011
Thank you John.
Steve@Avantgarde
Bristol/Somerset
Im pretty sure they are plug and play. It may need to be told some variant coding for country specific items, but it should fire up as soon as its connected and working.
mersum1es
Finland
W220 PSE pump is not p'n'p... but it is because so many different options, not sure how much variations W230 has
mersum1es
Finland
ok, CL may have more 'standardized' options, good that at least something is easy... :)
star
Reading
Smart + others :)
I think you have to program lumber support, everything else will work.
D
Doc47
SL 300 2011
Thanks everyone.
Submariner1
Windsor Berkshire
CL500 2009 5.5
Thanks everyone.
As Star said there is a guy in the US, who couldnt get Lumbar pads to pump up. OK on an S Class so might not be relevant.
Finally bought a new pump, and it still wouldnt work the Lumbar supports. He found it needed Star to configure the pump. He said they found it saying “not present” they changed it to “present” and it all worked perfectly.
D
Doc47
SL 300 2011
Just for feedback, I fitted a new PSE pump and everything worked p,n,p, except for the lumbar support which star and submariner indicated was correct, I will live without the lumbar support until I get it serviced again.
Thanks for all your help.
p.s. anyone want to buy a used PSE pump cheap.
parmacheese
2005 sl500
I've fitted 3 PSE pumps to SL's in the last month and every one of them fired up the CL and roof the moment they were plugged in.
Hi sir was hoping for some advise on my 2005 sl. Remote looks not working fuse is not blow or blowing in rear seat. When trunk lid is open lite at trunk switch is on but when trunk is closed lite foes off. I get get close trunk portion when I try to open top. Any advise would be much appreciated. Thanks
Pse pump is probably full of water or the ocb is damaged, boot seperator is wired into the pse pump.
