sl500amgsport
Ok when comparing try blasting in 2nd gear to 5000 rpm ;-) with roof off ;-).
Sent from my SM-G988B using Tapatalk
Stop start off since I bought mine. A gimmick that costs u cash for f, a.Interesting another reason to keep the stop start off, had mine programmed off on my SL.
The E53 though is pretty much designed around it!
2015 SL400, 41k, 2 owners, full MB service history and just about perfectI prefer those wheels over the others they put on the SL
Looks lovely
What is it ....
Is it easy to switch it off?Stop start off since I bought mine. A gimmick that costs u cash for f, a.
If you invest in a Smartop you can reverse the switch programming so by default start stop is off, you can also adjust the number of wipes after squirting the windscreen and increase the speed at which you can raise/lower the hood plus a few more bits...Is it easy to switch it off?
Thanks. Where are you?If you need to boot insert/First Aid kit I have one you are welcome to.
Near Colchester Essex.Thanks. Where are you?
