V6Matty
- Aug 1, 2012
- Location
- Newark, Nottinghamshire
- S212/2010/E350 (His) W246/2016/B200 (Hers)
Most tuners maps are not detected during an diag work, the main problem you might face is if there is a software update to the ecu, it would then overwrite the map file, that said it not likely but just something you need to be aware of.
Swapping back and forth isn't a major issue as a good tuner will keep a copy of the stock file, it will just be time and money to do,
