red battery charge and abc warnings
Chris Attwood
Spain
1997 C230 K W202 and 2002 CL 500 And SL 500
My 2002 cl 500 has a red battery charge, visit workshop warning and a red abc drive carefully warning. The battery warning was first followed a few minutes after by the abc warning.
I'm guessing battery charge is probably an alternater. Is it possible if battery is not charging it will shut down the abc system?
Yes its quite possible that a battery issue will impact other systems. First thing first - check the alternator output using a voltmeter.
C
Chris Attwood
Spain
Thanks.
m2287
Cambridge
Bentley Continental GT - S55K AMG - RR vogue - Mazda6 estate
Check that your drive belt hasn't slipped off.
m2287
Cambridge
I
It has and ripped now. How easy to change?
Very easy. No more than £50 at a garage including the belt.
I wonder why it ripped though, what's the mileage?
C
Chris Attwood
Spain
108k
m2287
Cambridge
Make sure none of the pulleys have siezed as this would throw the belt off!
C
Chris Attwood
Spain
From a brief inspection they look ok, what would cause a seizure?
m2287
Cambridge
A dead bearing, I think the AC pulley is common to seize, do any of them not spin straight if you get me?
Craiglxviii
Cambs UK
Btw a dead battery on the 215 can cause all sorts of warnings. I had -39 fault codes on mine when bought thanks to a flat battery.
